Positioned the wings close to the attach points on saw horses. Close enough to be able to connect the plugs from the fuselage to the wings. Items verified as working: Landing Lights Strobes Nav Lights Heated Pitot
Also did the Auto Pilot ground checkout per the manual. All worked as per the manual.
Next is new fuel lines from swap valve to the tanks and new vent lines. Both were too short when I had the wings on to drill the rear spar.
